For starters, Yes, I have checked the how-to guides on auido sync problems.
I used TMPGenc to encode a DivX file into SVCD format. So I now have a mpeg. However after about 30 minutes the video has small skip and the screen goes white, this causes the video to be about a quarter of a second behind the audio. I am wondering if ther is any way to get rid of this.
Did you try to see if the Divx needed to be fixed first? http://www.divx-digest.com/software/divfix.html
Good luck!!!!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
