    Jul 2001
    knoxville, tn
    I inverse telecine, temporal smooth and smart smooth in Vdub and save to multisegment AVI, then I open up the AVI segments and frameserve to TMPGEnc. This works fine, except that it takes 3 hours for 12 minutes of video (SVCD 480x480, 2pass VBR) on a 1.2GHz Athlon w/ 256MB DDR Ram. I was wondering if there are other methods of getting large files in to TMPGEnc that are faster. I am trying VFAPI but I can only get it to read the first segment, which does me no good, I could just do that by loading the first file segment in TMPGEnc and forgetting about VFAPI...Do I need to save a .tpr file in TMPGEnc for each file segment, then add all of these jobs in VFAPI?
  2. Im wondering if you could frameserve while you are applying the filters, instead of having to save the segments. Im not sure if that would even save you anytime.
    Jul 2001
    knoxville, tn
    The filtering is being done while I am at work, so if I could filter while frameserving, that would be very nice because the encoding & filtering would be done when I got home. However, I am performing inverse telecine & temporal smoother which can't be used while frameserving. I guess the best option would be to inverse telecine and filter in TMPGEnc, but I am more familiar with what it takes to get good results in Vdub.
