I have a Pinnacle Studio PCTV Rave capping card.
When i cap anything with virtualdub and play it later with windows media player, there is no sound. I have tried everything, reinstalling drivers, configuring settings etc. but nothing seems to help.
Is the line-in enabled in the recording mixer?
Is your line-in port getting an audio signal?
Are you capturing from the tuner or the video-in?
Does it make a difference?
What OS & driver type (wdm or vfw) are you using?
Does any other capture app get sound?
Do you hear sound while its recording? -
yes the line-in is enabled. i've checked it several times.
i've been trying to capture from TV and videocassette. No sound for both.
I have w2k and use vfw drivers.
Yes, the default application that came with my card (PCTV Vision, I believe) does have sound after capturing but when I try avi_io or Virtualdub I get no sound after capturing.
Yes, I hear sound perfectly when i'm recording, but after when i activate the recorded file, it's absolutely mute.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
