    May 2002
    Ontario Canada
    ok...here goes...i just ripped a movie and followed all the directions in the guide..so far so good..but I noticed that i was encoding it as an Mpeg file. How do i leave it as a single AVI file (or DivX would be even better). I don't want to burn the file to disc..just make it available for others.
    May 2002
    Ontario Canada
    I should add that what i want to end up with is a single AVI file. I use WinMX and have downloaded many AVI files that are called "DVD Rip". I have Smart Ripper and DVD2AVI installed.
    Apr 2002
    If you are following guides as per these pages, most of the How to's in the ripping section send you off to turn a ripped DVD into a VCD and assume you are going to play the finished product on a standalone DVD player. If I understand your process you are looking to end with an AVI as your finished product.
    You might try:
    http://nickyguides.digital-digest.com/flaskmpeg.htm it's been around a while and hasn't been updated for sometime but it all still works. This process will get you an AVI from a SMARTRIP.
    good luck.
  4. yeah, in my experience flaskmpg has been the easyest way to rip to divx... and the quality is really good for how easy it is.
