I have the 3cd copy of spiderman. I used tmpgenc to change to header of the svcd to vcd, then burn it in nero 5.5. When I go to play it on my standalone dvd player the picture is choppy and there are green squares and blothes all over. I just want to watch spiderman on my dvd player. It seems I am so close, any help would be appreciated. Thanks
Originally Posted by harris5108
Here's your Spidey Help:
Problem with TMPGEnc, SVCD -> VCD
http://www.vcdhelp.com/forum/viewtopic.php?p=261726#261726
Converting SVCD to VCD
http://www.vcdhelp.com/forum/viewtopic.php?p=261722#261722 -
Have you been able to play any other SVCDs? Reencoding a SVCD will take lots of time... As above SVCD->VCD might be your route if you can't player other DVDs. Centropy has the telesync thing down fairly well but I have had to reencode every release of theirs for various reasons, they are/were not good at mpeg2 encoding in several senses.
r the squares intermittent and appear and disappear? i had that problem with behind enemy lines, so i stopped using vcd easy and used another program, but the other program isnt available on a website. u may also try another copy of the movie. it may not be quite as clear but i have another copy of it and i actually think its a decent copy.
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
