Closed Thread
  1. Ive been trying to frameserve to Tmpgenc using VirtualDub but I cant get it to work. All I get is Tmpgenc freezing up and then I have to "ctrl+alt+del" to get out. Ive tired alot of stuff to get it to work ref:
    http://www.vcdhelp.com/forum/viewtopic.php?t=95688
    Please anyone who had the same problem please post.
    Thanks.
  2. This frequently happens to me. I just ignore the "frozen" instance of TMPEGEnc and start up a new instance which works fine.
    Brian
    May 2002
    Rainy City, England
    My problems were solved by putting msvcr70.dll in the sytem32 folder. However, I got freezes until I played around with the VFAPI priorities, then it worked perfectly.
