hi anyone recommend dvd player with macro disable and multi region? or any of these hitachi p315, jv xv s42, pioneer dv444, phillips dvdq40, samsung dvd105, alba. thanks
I haven't tried it yet, but I learned that there is a hack out there for the apex1100W (serial number must end in 05) for region codes and macrovision disabler. The price tag from Wal-Mart is $65-68.00.
if you decide on this one, BE SURE TO GET THE ONE WITH A SERIAL NUMBER ENDING IN 05. it is the 1mb version and not the 512 version.
As far as playability. It is not a snazzy as the other more expensive ones, however it plays VCD, SVCD, most XSVCD's, DVD's and does a neat job with my jpeg pictures(slide shows) It also plays raw mpeg files (don't kill the bit rate though.
Insignia multi-region?
By tpapictures in forum DVD & Blu-ray PlayersReplies: 10Last Post: 1st Feb 2011, 13:32 -
How to disable macrovision in Go Video DV1140
By wbsearch in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 22:10 -
Multi-format + multi-region
By ilank9 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Oct 2009, 07:14 -
Multi Region / Region Free codes
By Flying_Dragon in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2009, 08:10 -
help on region hack Philips DVD963SA from German to US/Multi region
By stieven in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 12:29
