I want to shorten a video file, and want to remove other portions and then splice the pieces together with as little distortion as possible.
How do I do that with VirtualDub and/or TMPGenc?
Or is there another free video editing program that will do those things?
thanks
just answered this in another post...and has been answered a number of times before.
But I'm feeling benevolent today 8) You may have to change a couple of the item and play with it, but the basics are right there.
bob12345,
If you have TMPGenc you already have what you need. I literally use it everyday to cut out the commercials of my ATI captures.
Go to FILE-> MPGEG TOOLS-> CUT/MERGE. If your capturing as an VCD compliant MPEG (cbr/1150k/224audio), be sure to choose MPEG1-Video CD in the drop down box.
Then, ADD your mpg file, EDIT it by using '[' and ']' to choose your beginning and ending segment. Do the same thing for each segment around your commercials. When done, click on RUN and a couple of minutes later you have your VCD compliant capture sans commercials.
_________________
Have a good one,
neomaineHave a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Have you checked this guides? For mpg..
http://www.vcdhelp.com/edit.htm
Or avi's Virtual Dub.
http://nickyguides.digital-digest.com/join-split-avi.htm
Parts of my clip are gray
By Maryarena in forum ffmpegX general discussionReplies: 12Last Post: 5th Jan 2011, 16:14 -
Burning Video clip files to DVD
By boraborasands in forum Authoring (DVD)Replies: 1Last Post: 14th Dec 2010, 08:32 -
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 16:25 -
how to edit/manipulate .exe files to remove parts?
By Xylob the Destroyer in forum ComputerReplies: 5Last Post: 8th Nov 2008, 14:56 -
Is VobBlanker good for cutting parts off of VOb files???
By mabhz in forum EditingReplies: 5Last Post: 28th Jul 2008, 03:01
