  1. When i burn SWEP2 to cd i get green all over the screen and the audio loses sync
    The files were originally SVCD
    I used isobuster for the bin files then converted them with dvd2avi then used TMPEG ot convert to mpeg
    Everything looks fine with the mpegs but as soon as i burn it goes to hell
    I am using nero to burn
  2. have you tried the vcd in a different player? I get the same thing when I play my vcd's in a sony dvd player, but on a computer its fine. Before you change things around, give it a try. Your player may not be able to read high bitrates.....
  3. Well
    i havent had any problems with vcds in this player b4
    i have also done the exact same thing as far as converting goes and they played fine in my dvd player
  4. if you've got .BIN files, just burn them as .BINS. try fireburner, i think you can get this at www.fireburner.com
    -Mark
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
  5. you can also burn the bin files in NERO, just go FILE --- BURN IMAGE -- load up cue sheet and burn.
    Aug 2001
    Västerås, Sweden
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  7. They r SVCD bins and my player does not recognize svcd so i had to convert them to mpeg and make vcds
  8. thats because swep2 is pal
    wrong frame rate
