As recommeded, I downloaded and used TMPGENC to encode my mpeg2 720 x 480, 29.97 fs to svcd format the encoding of video worked w/ 480 x 480 , 23.96 fs but no Audio came out.
Please help.
have you tried listening to the audio file seperately in WMP to see if there is any???
check all your audio setting in tmpgenc to see if you accidently checked or unchecked something -
brandonjh00, cause nero 5 complains about file format it says not a svcd format.
Could you suggest what better format for burning mpeg-2 720x480, 29.97 file to svcd or xvcd? and to preserve better resolution.
Thank you. -
I would download VCDEasy and give that a try.
I really dont know what to suggest though other than that. I'm not to educated on svcd. I have been burn everything just vcd, and usually use the nonstandard vcd setting in tmpgenc because i mess with the bitrates.
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
