When i download VirtualDub and TMPGenc they're zip files. On my computer .zip files always open in Abode or something and it doesn't work, i can't get VirtualDub or TMPGenc. Can someone tell me what to open zip files with? and if you don't know what to open it with can you just give me some other programs that are like VirtualDub and TMPgenc and are in .exe .
Thanks. I Don't Know how to do this stuff.
Originally Posted by aliahmed
Download www.winzip.com and install, make sure its associated with .zip files. Then right click the zip file and select extract to C:\TMPGEncetc etc This will recreate the sub folders correctly. -
I already unzipped TMPGenc with Winzip, but when i click it it says "This is not a valid Win32 application" and TMPGenc is not a exe on my comp. its a VPF File. Can you tell me what to do to make it work?
Thanks. -
By any chance do you have file extension view, switched off ?. If your file extensions are switched off you wont see the .EXE so you need to switch them on.
TMPGEnc folder does have a "TMPGEncVFP_Install.bat" but that's not the main program "TMPGEnc.exe" is. the folder should have theses sub directories inside.
Cache
Help
Template
Then a list of the other files, if your double clicking the wrong file you would get that error, you would also get that error if the program was corrupt, or maybe infected by a virus.
start again, download from http://www.tmpgenc.net/e_download.html
(http://www.tmpgenc.net/files/TMPGEnc-2.54.37.135.zip)
File size of zip is 1,011Kb -
P.S You did download the program not the plug-in ?
VFAPI plug-in for TMPGEnc project file (352KB)
TMPGEnc.vfp is the plugin
Windows 7 does not see my Zip Drive
By kimco52 in forum ComputerReplies: 16Last Post: 22nd May 2010, 21:16 -
.ISO zip file
By nodollas in forum DVD RippingReplies: 5Last Post: 10th Feb 2010, 18:07 -
.Exe vs .Zip Programs
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2009, 04:30 -
What is your most used zip compression utility?
By yoda313 in forum PollsReplies: 39Last Post: 30th Jun 2009, 17:00 -
AviDemux .Zip vs .Exe
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 19:53
Quote![Send a message via AIM to [ShaRk]](images/misc/im_aim.gif)
![Send a message via MSN to [ShaRk]](images/misc/im_msn.gif)
![Send a message via Yahoo to [ShaRk]](images/misc/im_yahoo.gif)
