I downloaded a movie where the audio and the video are not in sync.I was wondering which program i can use to fix this problem??
On the left of this page is a vertical panel with severl sections. One is labelled HOWTO, with several subsections. If none of the techniques in there solve your problems then by all means come back to the forums. Describe you problems and set up in as much detail as you can and then you might get a useful answer. But dont expect to be handed evrything on a plate.
Didn't expect everything on a plate,just wanted to be pointed in the right direction.I have virtualdub,but can't figure out how to use it for this problem.I kinda thought this was a forum for this.If it isn't,what is it for??
Thank you wee haggis.That is all I needed,a point in the right direction.Thank you for your time and response!
Fixing audio in a clip taken by a mobile phone
By shorto in forum AudioReplies: 3Last Post: 23rd Jun 2011, 07:34 -
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 01:03 -
Fixing An Audio Track?
By Prince Valiant in forum AudioReplies: 5Last Post: 5th Feb 2011, 19:40 -
Need help in fixing audio delay which builds up as the video goes on ..
By ahmadka in forum AudioReplies: 4Last Post: 29th Jun 2010, 09:56 -
Fixing AVI Audio - modular distortion?
By 00Billy in forum AudioReplies: 1Last Post: 3rd Nov 2008, 09:27
