    Right...
    i have d/l ed a couple of avi films and every time i goto play or decode or wotever i get errors... i.e unsupported format....
    i have all the divx codecs installed as i can convert all divx stuff to vcd & i don't think i would be able to that without all the relevant codecs.
    question is this - do i need a different codec just for AVI's?
    Is divx and AVI the same thing?!?
    Any help is FAAAANTASTIC.. :D
  2. Banned
    Jun 2001
    UK
    Right click the AVI and find out what codec it uses, then go get it
    You probably missed one, perhaps the new DivX 5
    DivX is a codec used to compress AVI's
    oooo yes..
    ok it says
    'divxmpg4 v3' under video compression...
    i assume that means one of the divx standards.... divx4??
    i thought i had 3 & 4 ...
    km8y thanks for your help... think i get the nimo codec pack...
  4. Banned
    Jun 2001
    UK
    Yep thats the Mpeg 4 V2,3,4
    Download "Mpeg4 Codec.exe" But don't tell Microsoft I told you....
