I have just installed a pioneer A03 and it is not recognised by Nero, uprgaded the firmware to 1.8 from Pioneer still no different, When You go to select writer the Pioneer has a red line through and cannot be selected.
Results 1 to 11 of 11
Sure it does... you probably have a problem with the installation of your drive. What does Windows report?
My A03 works great with 5.5.8.2
ASUS P4PE
windoze XP SP1
Radeon 8500DV
M-Audio delta 1010LT
2 x WD1000BB
Plextor 1210A
SoFo Vegas Video 3 -
You might want to check if the drive is operating in DMA or PIO Only mode. Whatever its on now, switch to the other and reboot. It's a common problem and is discussed on Pioneer's website.
The A03 can only operate in PIO mode. What does the Windows Hardware Manager say about this drive? Can you put a CD-ROM into it and read stuff on it?
That's incorrect. The drive is fully capable of running in DMA (mode-2) as well.Originally Posted by SLK001
Hummm, the DVR-A04 says that it supports UDMA-33. There is no mention of the A03 being likewise compatible (but I don't own one, so I can't do any testing/experiments).SLK001 wrote:
Pioneer BDR-205 requires HD video card to work??
By lafjax in forum DVD & Blu-ray WritersReplies: 4Last Post: 1st Jan 2010, 12:51 -
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 23:43 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
work-arounds for nero alphabetizing mp3 files
By Mustang.VxD in forum AudioReplies: 6Last Post: 9th Jul 2007, 00:54 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
