I have ripped an DVD and and saved it as an project in DVD2AVI
But tmpgenc wont open the .d2v file.
I have installed the VFAPI according to instructions but i still dont get it to work. What am I doing wrong here?
I had the same problem... make sure that the version of dvd2avi u r using is correct - i had to download a newer version from the official site WITH the plugin.. the version i had did not even have the vfp file!...also make sure tmp and dvd2avi are installed in the same folder & have u ran the vfp proggy?
check tmp under options/enviromental settings and the vfp tab... have u got a dvd2avi reader there?? if so maybe u can raise its priority.. if not it not installed??
i had to remove tmp and dvd2avi then reinstall to same folder.
after i done that it worked fine!Any help is FAAAANTASTIC.. :D -
after i done that it worked fine. dvd2avi i have is version 1.76Any help is FAAAANTASTIC.. :D -
THANK YOU!! my friend! It works like charm now!
I was going totally bananas there for a while!
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 16:16 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
