OK this is what I got...
I downloaded a supposed vcd from a mate, he doesnt have much of an idea what he has given me, think he might have just dragged and pasted whatever was found on the vcd
The files I downloaded are :-
swar.ccd
swar.img
swar.sub
swar.cue
The .img file being what I thought was the mpg, as its 700 MB...
Tried to rename the file in dos to mpeg, but that didnt work...
Then I thought maybe I could use cdrwin to burn it, but I dont know how to make a cue sheet, when Im not taking the files from a cd???
Any ideas on how I can make this work, took 70hrs to download the file
Cheers![]()
the files u have are cdclone image files. u could either install cdclone + burn that way or use deamon tool , its a virtual drive , u load the image into that and you can then view the contents(ie mpeg) u could then extract it or u could use whatever cd copy software u have and do a cd-cd copy using the virtual drive as the source.
Thanks mate, I am downloading cdclone and I'll have a crack at it that way
EDIT= actually I think it would be easier for me to try the other way.....searched google for the tool you mentioned, but Im not sure what exactly you mean.....maybe if you could post a link for me, that would be great
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
AVI to TS conversion/PVR play prob.lem
By sadid in forum Video ConversionReplies: 0Last Post: 24th May 2009, 04:43 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Are we getting more posts confusing conversion with burning?
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2007, 02:34 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 06:28
