Not enough storage is available to complete this operation.. what does this mean? i'm trying to open a divx/avi using windows media player..
is there a good video viewer out there?
For anyone that has run into the " not enough storage is available to complete this operation " error within Windows Media Player, I was finally able to fix it for myself.
My error only occured when I played MPEG files that were not MPEG-1 compliant. So, SVCD's or files I grabbed from my TIVO would not work.
To fix the error I downloaded the "SVCD Codec" from http://www.divxmovies.com/software/
When I ran it at first I chose to REMOVE the existing installation. It came up with some script errors and failed to remove the files. I tried to install the codec anyway and it would not let me load the files as it came up with an error stating that I already had them loaded. In my circumstance it said that it could not find Mpeg2Parser.ax in the c:\windows\system32 subdirectory. To get around the error I copied the Mpeg2Parser.ax to the c:\windows\system32 directory, re-ran the removal process and it worked. I then re-ran the exe and chose to install the codec and success!
FYI.. In my efforts to get this working I did load other codecs. Just incase this is a combination issue, here is what I did.
1. I loaded the NIMO Codec pack, basic options. This can be downloaded from http://www.btinternet.com/~nimosiro/
2. I re-loaded the Windows Media Codecs. This can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=31921&area=search&ordinal=2
I am running XP Home Edition SP1. I hope this helps.
Tivo Homer
Win 7 media player issues
By bnwbass in forum Software PlayingReplies: 5Last Post: 2nd Jul 2011, 09:15 -
Please help with Win Media Player subs
By Blackwell in forum SubtitleReplies: 0Last Post: 7th Feb 2011, 11:39 -
Transfer of files from PC to media player storage - Which brand/model?
By holmerz in forum Media Center PC / MediaCentersReplies: 2Last Post: 23rd Sep 2010, 07:57 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 04:32
