I JUST DOWLOADED A MOVIE.......AFTER DECODING ITTO QUICKTIME FORMAT ITT HAS CHOPPY SOUND......BUT NOT BAD
WHEN I TRANSFER TO VIDEO CD FROM TOAST .....AUDIO GETS WORSE
ANY IDEAS?
APPLICATIONS?
ANYTHING....?\
THANKS FOR ANY HELP.........
THANX DR.J
THERES A FEW DIFFERENT WAYS ......BUT USUALLY AN .AVI FILE
--I SEE A WHITE SCREEN WITH NO PICTURE BUT WITH VOLUME....THIS IS USUALLY FIXED MY DIVX DOCTOR, BUT IF IT DOESN'T FIX WHAT NEXT?
--SOMETIMES THE SCREEN IS BLACK OR GREEN BUT HAS AUDIO.....I CANT FIGURE OUT HOW TO FIX THOSE
--SOMETIMES I'LL DROP A FILE ON DIVX DOCTOR (A VALID FILE) AND NOTHING HAPPENS, DIVX DOC DOESN'T EVEN TRY TO FIX IT
--MY BIGGEST PROBLEM THOUGH IS EVERYTHING WORKS, DIVX DOCTOR, MPEG CONVERTER, AND BURNING IT TO A VIDEO CD W/ TOAST TITANIUM........I CHECK THE MOVIE ALONG EACH STEP TO MAKE SURE IT STILL WORK PROPERLY.....WHICH IT DOES, BUT WHEN I PLAY THE NEW VIDEO CD ON A HOME DVD PLAYER THE SOUND IS CHOPPY
^THE ABOVE PROCESS GOES FROM^
DOWNLOADING THE MOVIE
RUNNING DIVX DOCTTOR
CONVERTING WITH QUICKTIME TO MPG FILE
THEN BURNING IT ON DISK
I HOPE THIS INFO HELPS CAUSE I SURE CAN USE THE HELP
GO LAKERS
P.S. IF I HAVE A 30 KB JPEG FILE...HOW CAN I CHANGE IT TO A 15 KB FILE BUT NOT W/ STUFFIT....I WANT THE ACTUAL PICTURE TO DECREASE IN SIZE
THANKS AGAIN 4 ANY AND ALL YOUR HELP -
See if maybe this helps:
http://forums.3ivx.com/cgi-bin/ikonboard/topic.cgi?forum=2&topic=84
X- -
Check out VLC
www.videolan.org/vlc/
itīs a program that reads almost all typs of stuff
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
Video Capture on Mac
By jonlesterwhite in forum MacReplies: 4Last Post: 29th Nov 2009, 05:41 -
How to convert video format of a video made on iMovie on a mac?
By squeejiboo in forum MacReplies: 1Last Post: 30th Jun 2008, 07:47
