after smartripping, dvd2avi and tmpgenc
i burned a svcd with nero 5.5 and the video is 1/4 the screen size and all in the upper left corner .it also flickers some
settings are right(ntsc)(sefy's template)
the apex dvd has played many of these svcd's before(using sefys template)
the mpeg plays normal on the computer
the dvd is oceans 11
my hard drive crashed and i had to reload onto a new drive
am using newer versions of tmpgenc and nero than before
any ideas?
one more thing,
i cant play the mpeg (on the cd)on the computer once its burned but can play it before burned
Anyone?? -
my advise to you is:
use dvd2svcd. same quality (or better), but more failproof. -
I have had the same problem in the past while fooling around with different resolution sizes. My solution, be sure to double check your resolution size you are sticking with standard resolutions!!!
Weird (to me) subtitle problem
By alvabass in forum SubtitleReplies: 3Last Post: 31st Dec 2011, 13:50 -
DVDStyler weird problem
By xeroblast in forum Authoring (DVD)Replies: 0Last Post: 8th Sep 2011, 01:37 -
Weird Problem with Handbrake
By LegendaryLero in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2011, 00:20 -
weird computer problem
By deadrats in forum ComputerReplies: 23Last Post: 24th Jul 2009, 19:10 -
a weird memory problem
By ahhaa in forum ComputerReplies: 3Last Post: 6th Nov 2008, 10:15
