In the Source Range dialog, if the movie file is under 80 min do you drag the scroll bar to the end and press SET END FRAME. If I don't what do I do if the file is under 80 min and is able to burn on 1 CD.
Thanks. Please Reply Quick.
Don't do anything if you want the whole movie - just make sure source range checkbox is unchecked and go on about your business.
Need help converting to MP4 with TMPGEnc Express
By rede96 in forum Video ConversionReplies: 0Last Post: 11th Aug 2011, 16:29 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 16:06 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 15:01 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
