I was in the process of using TMPGEnc to convert my avi to mpg when my computer froze. What happened was I tried printing an e-mail i received during the conversion. Stupid move on my account, because now I have to manually shut down my computer.
Is my conversion totally lost, or is there some way I can start where I left off. If there is any way to do this I really appreciate it if someone fills me in on the procedure. I only had an hour left on it too!!
open the file you created and go to the end and see where it left off now go back to tmpge and press settings then advanced then check source range then double click source range now slide the bar to where it left off press the ( button then slide it to the end and press the ) button hit ok then start when its done merge them together or just burn them as two tracks
Funny thing is, when I go to open the file now it says the format is not supported. When I look under properties the file size is 0 bytes. I have opened mpg files before, but only when i converted them to VCD. I have never opened them when converting to SVCD.
Is it the codec that I am missing, or did the file get corrupt when the computer froze? -
I just downloaded Windvd and still no good. I am getting a message that number 1 file is invalid. Any ideas what this means?
Any info is greatly appreciated. -
This has happened many times to me, remedy: start again old friend you've lost all previous conversions.
No way back.I know its not what you wanted to hear.
DaveWelcome my son, welcome to the machine.
Isnt VCD obsolete?
By omega_weapon in forum Authoring (VCD/SVCD)Replies: 63Last Post: 18th Aug 2013, 09:11 -
ogm file with subtitles isnt working
By dudeboy in forum MacReplies: 0Last Post: 5th Sep 2009, 08:53 -
the movie isnt playing with consistency
By timmi in forum Software PlayingReplies: 1Last Post: 11th Jan 2009, 08:16 -
using xvid4psp, but the video isnt synching correctly...
By Kaminoshi in forum Video ConversionReplies: 18Last Post: 27th Dec 2008, 01:22 -
Interactive Photo CD which ISNT a slideshow?
By HBAndrew in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 21:25
