I have a divx that I am trying to convert to mpeg so I can burn a vcd.
I am using TMPGenc to convert it, which works fine, until I get ready to burn it.
Nero tells me it's the wrong audio format. Same thing with EZ CD Creator.
The divx properties are as follows.......
Width: 352
Height: 274
Duration: 2:06:30
Bit rate: 159kpbs
Audio format: MPEG layer-3
Frame rate: 25fps
Data rate: 82kpbs
Video sample size: 24bit
Video compression: DIVXMPG4 V3
Do I need to do something with the audio track from the Divx first.....before I convert it?
Thanks in advance.........
Audio for VCD (and SVCD) has to be MPEG1-layer2 with a bitrate no higher than 224Kbps. Sampling rate should be 44.1 KHz.
352x274? that's a little odd too, both numbers should divide by 16 (352x240 or 352x480 are more common). What template did you use in TMPGenc to make the MPEG file?
What's Wrong With This AVI?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 29th Jan 2010, 11:17 -
Wrong filter being used
By Igniss in forum Software PlayingReplies: 2Last Post: 12th Dec 2009, 05:18 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
