  1. I have the VCDVault Centropy release of Star Wars Ep 2 and the quality is outstanding however there is a serious flicker problem. I'm going to make it into an SVCD but I need to get rid of the flicker, any ideas??
    Realmedia! The Nectar of the Tards!
  2. They probably already did quite a few things to try to clean it up but you could try the deflicker filter for virtualdub. It should be here http://sauron.mordor.net/dgraft/index.html
    Let me know if it helps, but I would be suprised if they didn't already use it... Anyways it's a pretty good Telesync IMO and I have never seen one that didn't have noticeable flickering. If you want a perfect picture, go to the cinema again
    I have been re-encoding the centropy release and it's a bitch because #1 my player is very very picky when it comes to svcd and fixing the aspect ratio is a bitch, it is way off by default. After I finish my SVCD version of it I am going to make a 2 disc vcd version and will experiment with all the filters I can.
    Also I am sure you have heard it before but google is your friend and you can find some more telesync info
  3. The flicker is present in the TS itself. But to fix it, I found out the Temporal Smoother filter in VirtualDub works like a charm . Try it and see what happens .
  4. What setting did you use and was there any blurring?
