i just got a VCD from a friend
well it was just 2 cd's with both 1 file on
should be VCD according to him
so i try to play it in Wmp but that one says Format not supported
while other VCD's play without problems
then i try WinDVD which also says unsupported Format
then i tried Powerdvd which plays the file but after a while the image freezes but the sound continues
can anybody tell me what can cause this and or how to solve it
i tried a mpeg 2 codec divx codec nothing worked so far
Thx for the help
Results 1 to 1 of 1
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
