I"m suposed to make a video for school by monday. They have me a Sony DCR TRV520
I can't install it. Windows XP says it cannot find the device driver.
I've searched and searched but all I can find is specs and white papers.
They didn't give me a cd and I may not be able to borrow it over the weekend.
Please help
Results 1 to 11 of 11
I can install an AVC device on the firewire bus, but it says the device cannot start (code 10)
Does this help you any. http://www.ita.sel.sony.com/support/dvimag/digital8/Digital%20Camcorders%20Query_1.html
This is proboly a ice cream induced thought so i can not take no control for the above statment. :P -
well if all else fails, just use the analogue connections (capture). A possible solution is that you may need to update to dx 8.1
Nope.
It says it needs to install an AV/C Multifunction Device Driver
where can i download one -
Hi,
Ensure your OS is completely up-to-date, including DirectX 8.1. Only Win98 Second Edition, WinME, Win 2000 (I think), and WinXP support Firewire. Microsoft's Windows Update site is www.windowsupdate.comIt says it needs to install an AV/C Multifunction Device Driver
Try Sony's website: www.sony.com
Allan -
This problem is spreading.
I bought a Dazzle DV Bridge and it's detected as an AV/C Tape recorder/player
My hitachi camera isn't detected either
No one knows what the problem is?
Should I just reformat my hard drive? -
greg 12, have you actually tried to transfer data from the camera to the hd. What software are you using? I had a similar issue, and all i did was installed dx 8.1 and everything worked fine. when you read this, pm me on the new irc channel and ill see if i can help you out.
Hi,
Thats how my Hollywood Bridge is reported by numerous capture programs. It seems "everybody" assumes that any AV device on firewire is a camera... which taint necessaruly so.I bought a Dazzle DV Bridge and it's detected as an AV/C Tape recorder/player
Try using the "Scernalyzer" trial (see the Tools secion on this website) for capturing. I use the full version with excellent results. -
Hi Again,
A badly fragmented HD could/should show up only as dropped frames.
A really screwed-up OS environment could cause this kind of problem and could necessitate a reformat and reinstall. This is often faster than trying to resolve issues like this. If you do reformat DON'T INSTALL ANYTHING YOU DON'T ABSOLUTELY NEED BEFORE RETESTING THE "CAMERAS".
Allan
Easycap 2.0 problem with wireless camera...
By tmady in forum Capturing and VCRReplies: 9Last Post: 22nd Apr 2012, 04:30 -
Cannot Capture. Possible camera h/w connection problem
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Mar 2012, 18:12 -
Camera File problem
By sakisbax in forum Newbie / General discussionsReplies: 1Last Post: 10th Oct 2011, 16:33 -
Mini DV camera Video /audio problem
By didikai in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 21st Apr 2010, 10:10 -
Camera problem
By bozzel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Jun 2009, 20:30
