Hi,
I made a VCD onto a CD-R (80mins) using Nero 5.5.5 but it won't play in my DVD player. I made another one on a CD-RW disk and it played fine but I had to finalise it, which meant that it was a waste of the disk. Please could you tell me if you know of a reason why my CD-R disk won't play because otherwise it is going to be really expensive!
Thanks in advance
Jessie
P.S. The DVD player also won't play CDs I've burned even though it will play shop bought CDs. Hope that helps you!![]()
Sony DVD player by any chance?
Your player is picky about the media - CDRWs have different reflective characteristics than CD-Rs and are more likely to play on some players.
Check the DVD compatibility table on this site to see if there is a specific brand of CD-Rs that will work on your player.
http://www.vcdhelp.com/dvdplayers.php -
You guessed correctly - Sony! Thanks for the tip though. I've had a look at the user feedback on my player and I'll try out some other discs. Thanks for your help.
Originally Posted by jessieg
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
Playing JPEGS on a DVD player......Help
By efiste2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2010, 16:43 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
playing files on a dvd player
By rigger1972 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 13:23 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16
