Apple DVD player won't recognize the "virtual" DVD. It says No Disk. Any ideas on how to play my mounted DVD?
Mount the image via Toast without having first launched DVD Player. This is the sequence I go through to play DVD-Video content (either from a VIDEO_TS folder, a mounted image, or an actual DVD):
[a] Boot into OS X
[b] Start up Toast Titanium
[c] Apple-M to mount an image; select the image
[d] Mounting the image creates a virtual DVD drive that DVD Player recognizes as valid and will startup.
The version of DVD Player I use is 3.1.1. My OS is OS X v. 10.1.4. I have a summer 2001 G3 iMac. -
Yeah I know how to do it using DVD Player 3.x for OS X, but it only works for OS X 1.4, and although I only run OS 9 I have OS X 1.0. I was hoping for a OS 9 answer. Thanks anyway.
Not to be bitchy, but to be bitchy, you could have stated you were looking for an OS 9 solution.
Originally Posted by AntnyMD
problem playing blu-ray iso mounted on virtual drive
By ryoaska1 in forum Authoring (Blu-ray)Replies: 10Last Post: 26th May 2011, 12:56 -
Setting up wall mounted flat screen
By walker2plus3 in forum Newbie / General discussionsReplies: 8Last Post: 14th Jun 2010, 21:06 -
Cutting out the wind noise from microphone mounted on car roof
By 872156 in forum AudioReplies: 6Last Post: 14th Jun 2009, 20:50 -
Any long term issues with playing dvds on a side-mounted desktop tower?
By yoda313 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Nov 2008, 09:59 -
What's the best software to watch DVD's on my HTPC?
By jeffeb3 in forum Media Center PC / MediaCentersReplies: 4Last Post: 12th Jul 2007, 12:17
