i figured if you rip a dvd you can burn it without reencoding as it is already in the right format... am i right??
plus how long does it take to rip on a decent system?
how long to burn??
please help
thanks
i ripped a DVD in under 20 mins the other day.. it does not take long at all - i think it depends on ur dvd rom in ur comp and its speed... (i think)
not sure about ur ripping question tho... do you mean if you rip a dvd and then burn with a dvd-r? so you would be doing a 1-1 copy or do you mean some kinda conversion i.e vcd etc...??
burning ... again do you mean dvd-r or a cdr?Any help is FAAAANTASTIC.. :D -
Prob won't happen. most dvd's are too large for current dvd-r disks. So 1:1 copies are impossible unless the dvd you are ripping is very small.Originally Posted by newnoiseimage
this site here has tons of tutorials explaining how to cut the size or how to push it to two discs
Gotcha now. I thought you were wanting to do an exact copy of the DVD. No compression or cutting. The 1:1 threw me off.
New to video stuff...
By SiNNiK in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2010, 12:41 -
PXL2000 and other lo-fi stuff
By billythecrashsxcker in forum Newbie / General discussionsReplies: 0Last Post: 28th May 2008, 12:39 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 07:52 -
menus and stuff
By zinc in forum Video ConversionReplies: 4Last Post: 8th Dec 2007, 08:51 -
wanna capture some stuff but i can't.
By spoolintanabe in forum Capturing and VCRReplies: 7Last Post: 10th Jul 2007, 09:54
