  1. I don't know if this was posted before. I did a search and looked in the guides, but I did not find anything on it. If there are other topics on this, just put down the link to them, and that's all I'll need.
    What I'm trying to do:
    I want to create a VCD with a intro movie first, then a menu, then the feature presentation. I would like for the intro movie to play up to the menu, then to be able to chose where to go from there, or to play before the menu. So, when I press "Play", the first thing I see is the intro movie, then the menu.
    The software I am working with is Nero, Ulead Movie Factory, and VCDEasy, although CDRDAO is not supported. With Nero, I can make the menu, but it refuses to place a movie before the menu. Does anyone have any suggestions?
    My shameless plug - XavierEnterprises.net
  2. VCDEasy / VCDImager is the way to go...
    With VCDImager, you can do absolutely anything you want.
    http://www.vcdimager.org/guides
    Regards.
    Michael Tam
    w: Morsels of Evidence
