Could someone tell me which one of these is better for archiving VHS tapes on to SVCD? The ATI is much cheaper it says it hooks up to a VCR just like a regular capture card. Will the more expensive have that much better of quality? (looking at Circuit City's ads)
ATI Tech Wonder VE TV Card (Brand/Model: ATE 100703102CCS) $50
**OR**
Dazzle USB Digital Video Creator (Brand/Model: DZL DM4100) $200
Thanks.
SYSTEM SPECS: Gigabyte GA-7DXR, XP1700, 512MB, 80GB HD, PNY Geforce3, SB Value, Lite-On DVD, Lite-On 12XCD-RW, XP-pro w/ FAT32, Networked (Host).
I would get the ATI because it is a pci capture card,usb will give you
the worst video quality(1394 Firewire is the best).If you get the ATI
DO NOT load the drivers that come with the unit,download them from ATI.com
Pinnacle Dazzle 'DVC 170' Woahs...
By synthecypher in forum Capturing and VCRReplies: 4Last Post: 3rd Jun 2010, 22:02 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
Capturing from Hi8 Tapes using ATI or Dazzle DVC 90 ~more info inside~
By samyrk in forum Capturing and VCRReplies: 12Last Post: 18th Jul 2007, 09:54
