I am installing the Pinnacle Studio Deluxe. This is the second one, I had this same problem w/ the first, but I thought it was a faulty board and exchanged it. If you don't know this is a PCI board. When I install it, This Messsage comes up " Hardware malfunction NMI: Parity Check/Memory Parity Error The system has halted." I have a Dell with Win XP. Click on computer details for more. I have removed all other PCIs (exept those needed for the monitor) and have tried the card in most of the PCI slots I have. I found one that worked, but then it stoped working after two restarts! The error comes up just after I see the Windows desktop for a few seconds. Why does it jus stop working? Is it the drivers? I had a controller card for my new HDD, but I took it out. WTF is going on?
Chris
Results 1 to 1 of 1
Science is everything we understand well enough to explain to a computer. Art is everything else. - David Knuth
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 14:39 -
TV Tuner / Capture Card - WinDVR 3 no Audio after Windows Vista install
By buzzsaw in forum Capturing and VCRReplies: 20Last Post: 12th Oct 2008, 16:06 -
Any Hardware Gurus Out There: I'm trying to install OS on AMD64
By wiseant in forum ComputerReplies: 9Last Post: 6th Mar 2008, 02:11 -
Help install my USB PCI card Windows 98SE,have driver can't find hardware
By bnbhoha in forum ComputerReplies: 6Last Post: 13th Feb 2008, 13:58 -
Capture card malfunction...
By Anonymous4374945 in forum Capturing and VCRReplies: 2Last Post: 24th Jan 2008, 01:32
