There's a CDV I'm trying to make, consisting of 41 different clips. When I burn this disc, my player always freezes up on one or more of the clips. I've tried burning about 10 discs so far (thank god they're only 20 cents a pop), and get the same problem. I thought maybe it was bad encoding, but it's not the same clip (one disc will always get hung up on chapter 3, while another gets stuck at chapter 8, and another gets stuck at chapter 38, etc.)
I've tried burning the discs at 8x and at 4x, but get the same results. I've tried burning with extensions on and off. I've tried making a disc image first, then burning from that. I've tried a more expensive blank disc. Nothing works.
Could it be that some of the clips are under 12 seconds in length? Anyone else have this problem?
It did work fine when I burned a copy without a lot of the really short clips; but I can't see why most of them work, except for one or two...
