I had vcd easy installed on computer which is running in Windows XP and it was working fine until today.
Now when I go to it is says "no cd writerreader found, or aspi problems.
I have done the aspi check and that is okay, so what happened and what shall I do? It's driving me nuts.
I tried using the latest aspi drivers from Adaptec and VCDEasy would not recognize my burner. I reinstalled forceaspi and everything worked fine. Here is the link for force aspi. I am running ME.
http://www.cd-rw.org/software/cdr_software/cdr_tools/frcaspi.cfm -
It would appear the the newest version of Adaptec's ASPI for download (4.7) is a little bit screwy...
I strongly suggest using the older version (that comes with ForceASPI).
Regards.Michael Tam
w: Morsels of Evidence
Hardsubs Easy
By kazz0817 in forum SubtitleReplies: 1Last Post: 22nd Jan 2011, 04:44 -
How easy are forced Subs?
By stephens in forum SubtitleReplies: 0Last Post: 6th May 2010, 12:19 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 08:07 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
Need an easy all-in-one DV to DVD solution
By kyroha in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:16
