I don't know if it's due to different computer systems or what (I have a pretty fast PowerMac G4), but when I exported my raw video to Quicktime using Motion JPEG A, the results were horrible. Everything was slightly blurry, and any small text in the picture was completely unreadable (before and after burning it to a CDV).
So instead, I exported the raw video to Quicktime using the DV-NTSC option (full quality), which gave me incredible clarity when burned to a CDV.
Also, when I use Quicktime to encode my files to Toast, it drops frames every few seconds. So I use Cleaner, which takes about 7 times as long, but gives me great results.
Anyone else have similar results???
What is CDV? Do you mean VideoCD? Also, is Cleaner still available only for OS 9?
I'm sorry, I did, indeed, mean to say "video CD" or "VCD." I guess I was thinking of "CDR"s and put the "CD" in front.
As for Cleaner, I don't know if it's out for any other OS, as I use OS9, myself.
Trying to modify .VOB file - why didn't this work?
By brassplyer in forum Authoring (DVD)Replies: 8Last Post: 7th Feb 2011, 23:03 -
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 16:07 -
hacks for samsung DVD-P191 didn't work..
By anoud9 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Oct 2009, 23:48 -
My new Harddrive didnīt work, to weak computer?
By Espen in forum ComputerReplies: 6Last Post: 24th Sep 2008, 14:47 -
DV to laptop via firewire? 4200rpm didn't work. Will 5400rpm?
By Colmino in forum Capturing and VCRReplies: 9Last Post: 19th May 2007, 21:46
