Is there a Tool to smooth the DVD when it plays Out??
I used TMPGE to Combine two MPG file the I used Spruce it up to author it and write Title-Audio, Video file then burned it with Nero... When
I test it, using power dvd xp, after it's burned it skips and is slow at some points... The audio is faster then the picture...
Before I author it I tested, the Combine MPG file in simulation mode and it's fine, but after the audio and video file is made and I burn it, its a little off. I am using same Media I use for all my dvd's and they work fine.
)1
Is there a tool to smooth it out
2) because when I test it with windvd it played smooth, it used some convergence as it played-*convergence win dvd2000
3)when the audio and video file is made is there a certain order you must drag the files into nero for burning or do I just drag the file in and burn it?
ThanX
Results 1 to 1 of 1
JayDot~..........
Smooth accelerated video
By Bluelemmy in forum Newbie / General discussionsReplies: 24Last Post: 24th Feb 2014, 18:13 -
filter to smooth playback?
By kinglerch in forum EditingReplies: 14Last Post: 21st Oct 2011, 14:17 -
smooth slow motion
By nitrobaorder in forum EditingReplies: 22Last Post: 18th Oct 2010, 07:19 -
DVD to MP4 conversion playback not quite smooth.
By scottb721 in forum Video ConversionReplies: 1Last Post: 21st Jun 2010, 10:45 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 18:23
