    Mar 2001
    Somewhere on planet earth
    I want to use the the intro song from series as background music for a VCD motion menu. I've already converted the file to MPEG and didn't think about using that intro song until recently. Unfortunately I no longer have the DVD. How can I extract just that part of the audio? What tools should I use?
  2. I am not 100% sure but you could split sound and video (de-mux) and then just cut out sound that you want from the wav. It is probably easier to try to find the audio/music on a p2p or some other file sharing program.
    Hope this helps
    VCD4ME
    We were all NEWBIES once and the only stupid question is the one that's not asked?
  3. start from what VCD4 just said then open the mp2 sound file in a sound program like SF5 and it is easy to cut where you want to....
    Bonne chance......
    "OO"
    P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
