  1. Under output settings/volume don't exceed I figured ou t the custom chapters, but If I do 74min vcd will it create files that will fit on 74min vcds? Just wondering b/c I don't want a 1.8 gb mpeg file I have to split in order to fit it on cdrs.
    Jun 2001
    australia
    just set the volume dont exceed to the size of disc that you will burn too. ie 74 min , for 74 min cdr and 80 min cd for 80 min cdr's.
    if you want one file set it to infinite.
    and if you want one file for each chapter then set the custom chapters.
  3. Thanks,
    will do
