Hi,
I have some movies as .dat files.
I have windows 2000 and media player 7 installed.
I am not able to play the movies. What is the software needed to run these movies.
Also what is the software needed to convert into normal files using which i can view the movies in all players.
I will be thankful if i can get the software names and the exact links.
Results 1 to 9 of 9
You can convert .DAT files to mpeg files using VCDGear (www.vcdgear.com). You can directly play the .dat files using windows media player, just associate .DAT extension with it. This applies for both VCD and SVCD. BUT you need the MPeg2 codecs installed for SVCD. They are available from a variety of places (this site for one)
Hi,
how to attach the .dat extension to my media player.
In the file formats,i do not see the .dat extension to attach.
one of my friends were telling me to install a codec driver for .dat file support..but from where i will get that.
Is there any solution to play this..or any other devices which support playing .dat files directly.. -
Try play with windvd or powerdvd.
and please don't make new topics with the same questions. -
Hi,
I have seen those players,but all are for 30 days only.
Is there any solution to my media player then.
how can i run the .dat movies in my media player then. -
To attach .DAT just double click on the file, Windows will pop open a window asking something like what application do you wish to play this with. Choose Windows Media Player (mplayer2.exe).
Yopu can also use Windows Explorer, Tools Menu, Folder options, File Types to do the same. -
Hi,
I have tried to open the .dat file by double clicking and opening it in media player,the media player does not recognise the file format.
What to do.. -
Most likely they are SVCD type files (MPEG2). Have you installed the MPEG2 codec elsewhere on this site. Otherise try using VCDGear (www.vcdgear.com) to convert tham to .mpg format.
HELLO EVERYONE
ever try just renaming the extension from .DAT to .MPG ?
works for me everytime" I am the one which you do not want to see, becasue I am the one which makes you see yourself" H.R.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
How to convert a DVD to a NORMAL AVI file using XviD4PSP?
By coxanhvn in forum DVD RippingReplies: 3Last Post: 8th Jan 2009, 15:31 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 05:19 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
