When I add subtitles to a movie in "letterbox" format, the subtitles is on the movie, (witch is fine if I am converting to "fullscreen")
But is there a way to add Subtitles the to buttom "black area" in letterbox format ?
I am using VirtualDub and TMPGEnc, just like described on this site !
Check the order of the VD filters. If the subtitle filter is the last one, the subs should appear on the buttom border. Also you should be able to adjust the position of the subs. What kind of subs we are talking about and which filter do you use?
I am only using the Subtitles filter, and it is Virtual Subtitles Filter.
Do I need to convert (using another filter) the movie in VirtualDub, to be a "Letterbox" format before I encode it in TMPGEnc ?
The Movie is in Divx format !
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
How to "reverse letterbox" 4:3 video?
By gonzoron in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 01:34 -
Autodesk Cleaner: adding letterbox black bars ("widescreen matte"
By sybariten in forum Video ConversionReplies: 2Last Post: 13th Mar 2008, 07:57 -
how to create "letterbox" bars with Total Video Converter
By zomigi in forum Video ConversionReplies: 6Last Post: 31st Jul 2007, 09:47 -
Cropping "Letterbox" Problem
By KatCassidy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th May 2007, 08:48
