can I encode several movies at the same time using TMPGEnc on the same machine? Are there any issues I should be aware of (apart from machine performance)?
Thanks.
Yes, I have done it a few times. Some peaple have said you get a performance boost doing this (ie two fines encode faster than if you so them sequentially). I haven't found this, BUT it is useful when encoding a long program and then you wish to do a smaller one for some reason.
PS I have noticed that running VirtualDub simultaneously really affects TMPGEnc (even lowering priority) -
I say having two TMPG windows is faster than one running a batch of two. If you look at your Performance under Task Manager you will see that your computer is not running at 100% all the time. I see my CPU Usage bouncing from around 55% to 100% - even if I set priority to high. I think it's higher when encoding mpeg-2s.
Run another copy of TMPG and set it to Idle only just to keep the computer running with whatever power is left and while you set up another single or batch encoding.
Seven
Dell Precision 620
Dual 800 Xeon
512 RDRAM
DVD Flick Run-Time Error 13
By amrcnbut in forum Video ConversionReplies: 2Last Post: 28th May 2011, 16:50 -
iTunes 8 displaying a few songs with the wrong run time
By Nintendo Fan in forum ComputerReplies: 26Last Post: 8th Jul 2009, 19:34 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 15:37 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 22:01 -
Rebuilder Run-time error ‘52’
By coody in forum DVD RippingReplies: 2Last Post: 4th Jan 2008, 12:03
