When I encode a NTSCflim to VCD, the movie is in "a black box".
Witch is fine.
When i put subtitles on movie, they are on the movie, I want to have the subtitles in the buttom "black area" ?
How ?
I always put subtitles in the bottom black bar. To do it, you have to use VDub and Avisynth.
1. Open your AVS file in VDub.
2. Go to Video --> Filters ---> Add --->VobSub
3. When prompted, choose VOB files
4. Click OK to create idx files.
5. Click Configure
6. adjust x, y to position subtitles.
You can preview your subtitles in VDub, if it's not what you like, you can always go back to adjust it. When it's done, go to File --> Frameserve Mode, save it as .vdr file, then open it with your encoder. You are ready to go.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
