What can I do to speed up my encoding speed?
I think you will need to provide a little more information before anyone can give a serious answer
Perhaps you should first check if you can speed things up by using a different approach.
For example: If you frameserve from virtualdub and you use a resize filter, using "bilinear" instead of "bicubic" can speed up things dramatically. Only use bicubic when you need to enlarge.
Use a faster encoder like CCE instead of TMpegEnc.
You should give us more information what method you use.
Shimrod -
This came up in a thread in the last week. Other than software settings, you'll probably only find a faster CPU will help with encoding.
Less than 3 months after getting my P4-2.0 it looks like that will be the CPU they are pushing and discounting (ouch). Gateway is advertizing a system with flatpanel LCD(?) for $999Panasonic DMR-ES45VS, keep those discs a burnin'
[FFmpeg] Up encoding speed for wmv's
By Klagar in forum Video ConversionReplies: 5Last Post: 24th Jan 2011, 13:00 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
decreasing encoding speed with mencoder (mplayer)
By sammy82 in forum Video ConversionReplies: 2Last Post: 1st Apr 2010, 23:58 -
can you speed up encoding with ripbot x264
By zerocoool in forum Video ConversionReplies: 6Last Post: 26th May 2008, 21:07 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41
