Please don't ask me why, 'cause it would take all day to type in an explanation.But here is my question: What would be the easiest way to encode a movie to play backwards? Well, not actually the whole movie, just a snippet of it.
I have tried using TMPGEnc, setting the START source range at the END and the END range at the start, but that did not work. I only ended up with a 10k empty MPG.![]()
Same thing happened using the MPEG Tools to cut it out of an existing MPG. Only it started encoding a part of the movie before the actual END range i had set.
Any help or suggestions are welcome and appreciated.
Xanthas
YES
In Premiere there are 'filters' perhaps in other consumer NLE also.
For the $$$ challenged there is VDub .Virtual Dub itself won't but i gather it will with 'avisynth'.
http://sauron.mordor.net/dgraft/faq.html
follow link - bottom of page - dl avisynth
look here also
http://www.videotools.net/doc/doc.htm -
I appreciate the info holistic, but from what I read (i actually did a quick skim) this is not quite what I was looking for.
I want to take an actual MPG and save it reversed not just play it in reverse. Make Sense?
I can do it with TMPGEnc by saving the clip as sequenced bitmaps and then renaming them in reverse order and re-encoding them. But that would be too tedious of a task. Unless that is the only way, or should i say the easiest way, to do it.
Thanks,
Xanthas -
I understood. 123456789 to 987654321
If you go to the second link - then scroll down to "Reverse" you will find it is the avisynth 'command' you are looking for.
Cannot help you further as i have not use avisynth in this way.
Xanthas,
In Premiere, you can set the speed of a clip in %. If you set a clip to negative 100% (-100%) it will play normal speed backwards. Export the file and you are done. -
Helmut
# SNiGLA @ EFnet
# vcdhelp @ EFnet
# vcdhelp @ DALNet -
I appreciate all the help. I'll give the avisynth a try and se how it works. That is until I can get ahold of Premier.
It's sounds much easier to do. And that is what I'm looking for.
Thanks again,
Xanthas
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
