i have movies dowanloaded on my harddrive and trying to put them on dvd r. is there anyone out there that has done this. please reply
i have downloaded a couple of divx (high quality) and AC-3 episodes of angel over the net (Fox won't put this release for at least 2 years).
What i do is convert the video stream to mpeg2 VBR, changing a bit of DVD templates (altering the bit rate), using 16:9 as source and as destiny. This way the DVD will be anamorphic. (Using TMPGEnc)
For the audio i extract the ac-3 from the avi (Using VirtualDub). It comes in a non-standard form, so you have to run headac3 to fix the headers (you won't lose quality in the sound, as the only thing you change are the headers).
Then using a DVD authoring program, you can multiplex audio and video and you get a great quality DVD(The audio is the same of those fellow britain / australian original DVD's)!!
Decent DVD recorder that plays AVI (DivX & XviD MPEG-4) w/HDMI out?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Feb 2012, 20:20 -
How to put dvd's onto portable harddrive & play on tv?
By frangapanni in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2011, 02:05 -
Is it possible to put YouTube videos on DVD?
By chithanh119 in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 04:55 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 04:39 -
How Do Take The Video & Audio Off Of My Computer & Put It On A TV?
By Ghettorapboy7 in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2007, 11:25
