I have seen that When I changed resulation settings on GKnot bitrate tab,Avarage bitrate don't change.
Don't To change resulation settings effect the avi size or avarage bitrate.?
In uncompressed AVI, if you increase the frame size, you will also increase the bit rate. If you increase the color resolution, you will also increase the bit rate. Bit rate = frame size x color resolution (+audio)
In encoded (or compressed) video, if you keep the bit rate the same, and increase the frame size, you will get more compression artifacts.
DV-AVI / Format size
By willmington in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 10:49 -
Encoding AVI's by Size
By OrchestraAndChoir in forum Video ConversionReplies: 6Last Post: 15th Sep 2009, 15:40 -
AVI to Subtitled-AVI = same size
By kevin182h in forum SubtitleReplies: 5Last Post: 18th Feb 2008, 16:57 -
Disable the playback buffer for quick interaction.
By youblokle in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2007, 17:16 -
Avi -> Smaller size
By gamerinha in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2007, 11:29
