I'm having a problem correctly making the svcds. When i play the SVCD on the computer it looks and works great, but when i play it in the standalone SONY dvp-s560D the movie is not viewed right. It doesn't properly fit the tv. A little bit on the right hand side is cropped off. How can i fix this? I need help. I'm using virtualdub for audio and tmpgenc for the encoding of mpg from divx. Using the standard SVCD FILM format (480x480 23...fps full screen aspect ratio on 1:1 VGA Non-interlaced .... and so on) Someone help me please.
I figured it out but i had to make the picture size smaller out of the 480x480. Had to change it to 425x255 for the actual image. But, i could fit the entire movie on 480x480 with 460x270 if i can move the video to left without while leaving a gap on the right.
hopefully this little thing helps:
____________
|__________|
||________| |
|___________|
looks crude but it should get the idea out. Anybody know how i can do this? all i want to do is move the video over to the left a little so my sony tv can view it properly without me having to sacrifice a lot of space. Someone please help me. -
sorry, didn't know it would come out messed up.
___________
the pluses are just like extra room. I need that room to make the video to work properly
Sony dvd - DVP-NS728HP/B USB video problem
By dreamcast in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Oct 2012, 22:56 -
Sony DVP-SR200P problem
By Andy312 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Feb 2012, 19:53 -
By dreamcast in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 15:26 -
Problem with Sony DVP-NS355 : Gets stuck at welcome message!?!
By Nilhanth in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Jun 2007, 13:44 -
Sony dvp-s336 and DTS problem
By ManWithaPlan in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th May 2007, 14:28
