I am using the kvcd template to make vcds, and I am using VBR 2-pass. I am wondering what the difference is between the following:
Average bitrate: 1600
Max bitrate: 2000
Min bitrate: 1200
Av. br: 1600
max br: 2200 (more range hi to lo)
min br: 1000
av. br: 1600
max br: 2000 (more range to high than to low)
min br: 1500
I want to make the best use of this technique, that's why I am asking. Also, will I get a higher quality with VBR than with CQ (CQ is the default in the KVCD template)
Andy![]()
CQ mode will give you higher quality than VBR. But the file size with CQ will be unpredictable ( sort of ).
You can read about CQ vs. VBR modes here:
http://tangentsoft.net/video/mpeg/enc-modes.html
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 15:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 19:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
VBR, ABR and CBR ??
By moiz in forum AudioReplies: 11Last Post: 19th Oct 2008, 18:22 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 15:28
