I converted this DVD to divx 5 successfully. I set it to amplify the audio to 2x the input. This usually works fine, but when I went to play the video, it's still too quiet. How can I use FlasKMPEG preferably or something else to encode just the audio? After that, I can use VirtualDub to put the audio in and align it to the movie.
Why is it that I've asked like 4 or 5 questions that are valid and correct questions for this forum and no one has responded. They also aren't hard problems. Certainely someone has some clues or insight they can share if they don't know the entire answer.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
