I have created a home video using videowave 4.0 and produce mpeg2 w/ 720x480 resolution. The file runs on my ATI file player and looks great but when I was burning it as SVCD using Nero 5.5.8 it prompts me with a Nero complain about the standard saying incorrect settings.
-Can you suggest any programs I could use to convert my mpeg2 file compliant to SVCD standards.
-And also when you burn SVCD, what files are needed to make it play automatically.
Thank you in advance for your help.
To make svcd standard use tmpgenc and select svcd template also need mpeg2 plugin
<-----look at Tools on the left
Then burn in Nero -
just turn off the standard compliance and you should be ok i have done many svcd's this way. just make sure you dont encode it at too high a bit rate or you will get framejitter.
certainly agree with cheftaz it takes about 10 years also.....
Thank you very much for the help, greatly appreciated.
More power to you guys.
Keep up the good work!
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 02:22 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
