I'm trying to convert an SVCD file to a VCD compliant MPEG: my DVD player won't play SVCDs, even after renaming headers. I've been successfully using DVD2Avi and TMPEG to do this.
The problem I have is with a movie containing a few corrupted frames about five minutes in, which stops TMPEG in its tracks. I've tried encoding two seperate files, one before and one after the bad frames, but the latter part of the movie is jerky and out of synch. When I try to just cut the SVCD file in TMPEG things go out of synch too.
Can anyone suggest a way of repairing the SVCD file, or of cutting out the offending frames, so that I can get a succesful conversion?
Thanks in advance.
[The file I'm working with, by the way, is episode 23 of "24", the Hawgsmacker version.]
Results 1 to 1 of 1
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
MOV to FLV Conversion Stopping Short
By IrishP in forum ffmpegX general discussionReplies: 10Last Post: 22nd Jun 2011, 04:43 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
